Strange mirror reflection issue in render
Hi
Can anyone help me with this mirror problem?
The reflection in the mirror is very strange, very frustrating.
has this been fixed in 3.3?
I like to hear it!
thanks in advance
@Woon_interieurontwerp , welcome to our Forum. :slight_smile:
If you have the chance, give our latest Preview Version 6 (click here to acquire) of Enscape a try as we have made improvements to reflections generally which have been implemented since Preview Version 4. This may help here to some extent.
Feel free to get back to me again through this thread to report back afterward - We appreciate all the feedback we can get about our preview versions especially.
Hi Demian
Thanks for your quick response.
When I got home I immediately downloaded the new version. unfortunately the problem persists.
Do you perhaps have other options?
I like to hear it.
<img src="https://forum.enscape3d.com/wcf/index.php?attachment/36870-pasted-from-clipboard-png/" class="woltlabAttachment" data-attachment-id="36870" id="wcfImgAttachment0">
<img src="https://forum.enscape3d.com/wcf/index.php?attachment/36871-pasted-from-clipboard-png/&thumbnail=1" class="woltlabAttachment" data-attachment-id="36871" id="wcfImgAttachment0">
Has the other behavior you experienced in the second image (the artifacts on the reflected door) improved/cleared up if I may ask?
Furthermore, if you’ve already set the Rendering Quality to Ultra in the Visual Settings (first tab), then you also mainly want to adjust your perspective to make this specific behavior less or not visible. While we improved upon our reflections (more specific details with some examples), some artifacts can still occur. It’s simply still a side-effect when having reflections rendered in real-time, but we’re aware of that and are doing our best to further improve upon these reflection whenever possible, up to what is technically possible.
On top of maxing out the rendering quality, making use of a raytracing capable graphics card can also help with reflections and the quality of sun shadows, just so you are aware.
Hi Demian,
No, the reflection is also the same in the other photo... Now that I've downloaded the new version 3.4, the materials from the enscape library n longer load in Sketchup... so frustrating
Hi Demian,
look the reflection remains the same .. I can’t send this to my customer anyway. Is there already a solution? I am otherwise forced to switch to another program.
I’m afraid, as mentioned these are normal artifacts of our real-time rendering solution - If you’ve made sure that the Rendering Quality is fully maxed out, you may still want to position yourself a bit differently to hide those shortcomings. Offline rendering engines (like Vray) will not display such artifacts, but they also will not allow you to navigate your scene in real-time with the fidelity Enscape provides.
We’ve also created an FAQ article here which goes into a bit more detail when it comes to artifacts in reflections. Simply put, ideally, you want to have everything visible on the screen which should also be reflected properly. I know this isn’t always possible, but just so you’re aware.
