1. Enable VFB
2. Add a vray render channel (ex: VrayAlpha)
3. enable split render channels
4. send job to backburner with stripes
get error at all servers after receiving job without starting render: ERR Task error: An unexpected exception has occured in the network renderer and it is terminating
Meanwhile, vray channels succesfully rendered by stripes in the network with simple max framebuffer.
thanks
It seems that trouble in possibility in 3dsmax 2010 to render channels by stripes, but enabled VFB crashing it down.
Solution is only in disabling VFB every time before network rendering
Ah, that would be the new OpenEXR saver? When the V-Ray VFB is enabled, V-Ray does not allocate and does not generate the normal 3ds Max render elements, which is probably what confuses the saver.
Can you get me a scene set up to crash to vlado@chaosgroup.com? I can’t make it work either way, but at least we might be able to prevent the crash; you’d still have to use the 3ds Max VFB to get what you need though.
