rendered with VFB channels
i have installed vray 1.6 beta and i test more simple rendered.
When i use VFB channel, i can see transparency in my rendered (see attached file).
In older version, i didn’t have this problem.
Do you have this problem?if this is really a problem…
I’ve also seen this bug, but it was intermittent so I haven’t identified what caused it. Perhaps try saving as tga?
ok i always render in EXR format because i have a small configuration of pc, and in png or tga, sketchup crashes when i want a good resolution.
