Specify Starting View
The current organisation and rearranging of photos and floor plan (either by Name, Custom Order, Modified, or Created On) is… clunky. And it can often mean that the image marked as floor plan ends up in a random position and having to then be dragged (painfully) back to the first position. Or the tours when shared start on an image that isn’t really an intuitive place for the tour to begin.
Given naming/sorting/starting view etc. behaviours are likely highly dependent on the individual, a useful feature may be the option to specify which view is used as the starting view? Or, given that it currently seems to always default to the first image, if there was a way to ‘pin’ the floorplan marked image to the start. Actually I can see some arguments against that… In any case, the gist of the request remains - a better/easier way to specify which view the tour begins on please :slight_smile:
It does sound like an improvement in the User Experience we can make. Currently the 1st file is always the starting view. We also have an idea to implement a Landing Page that you would be able to define with information about the project and serve as a cover/branding page. We can discuss some of these things in a call as I suggested in one of your other posts.
