Virtual Tours/Hotspots - General UI Improvements
Status: new
I’m really trying to push Virtual Tours as part of our standard offering but there are pain points that continually cause frustration. Some are tied to the Enscape/upload process, which I’ve raised separately, but some are to do with the Virtual Tours themselves.
Perhaps because we don’t utilise Cloud Collaboration for anything other than Virtual Tours we’re missing a piece of the puzzle, but I would have thought a reasonable portion of users would be in a similar position as us (i.e. only use the Virtual Tours)?
  • Hide/Deactivate Hotspots
    I raised this a while ago (and attempted to resurrect it recently) in this thread:
    But am still yet to get a response. Perhaps no one else feels the same, but we continually run into scenarios where we want to set up the virtual tour, get the views and hotspots established, and have placeholder or quick draft panoramas set up. We then want to start sharing the tour, but only begin with a selection of the views actually viewable. Later on, we may want to remove some of the views from being viewable. There’s no mechanism in place to hide/deactivate these views without destroying the version history, the hotspot links, etc.
  • Only Share The Tour, Not The Tour Homepage
    In line with the above, and the recent thread I just started here (which should have probably just been captured in this post, apologies, feel free to merge) :
    Limit Share Visibility To Only The Tour
    If we do get views that aren’t publicly viewable or are disabled then it’s even more reason for viewers to not be able to click the “back” button and go to the main tour page and see all the hidden images and creation dates
  • Multiple Floor Plans
    Trying to cram a 3 or 4 level building onto one page is limiting, are there plans for multiple images to be marked as floor plans? There are some workarounds involving hotspots, but it involves several clicks in order to get to the correct floor plan image to then click on hotspots.
  • Scroll in On Floor Plan
    The actual floor plan view can be scrolled in and out (like all views) which is handy for when the hotspots start covering too much of the plan or there are multiple hotspots in a condensed area. However, when in a panorama view and clicking the floor plan swatch to bring up the ‘quick access’ floor plan, this plan isn’t scrollable. And the only way to get back to the ‘full size’ plan is to mainly scroll through the carousel and find it, which isn’t a great virtual tour experience. So could the ‘quick access’ floor plan also be scrollable/zoomable?
  • Hotspot Icon Flexibility
    Can the icons be allowed to be smaller? The current smallest size is still rather large (although it somewhat goes hand in hand with only being allowed one floor plan and having to cram multiple levels in one plan image). And there are some arrows, but they’re locked to always pointing up - can we rotate them? And potentially even upload our own image/icon files?
  • Allow Floorplan To Be A Hotspot
    The image marked as being the floorplan seemingly can’t be linked to as a hotspot, is this intentional and unavoidable?
  • View/File Management
    Management/organisation of files in tour home page is… clunky. Firstly, the only file display option is with thumbnails, and always of a fixed size. Just about every other file interface I can think of allows multiple display options - list the files, list the files with details, show thumbnails but allow the size of the thumbnails/grid to be adjusted, etc.
    In order to re-order the views it requires so much manual clicking and dragging, one file at a time, and something that’s at the bottom of the pile that needs to move to the top requires so many stop-start-scroll up actions.
    The more I think about it though, the more I’m wondering why the file ordering has to allow for custom order anyway? Why can’t it just be like every other file management interface and the files are the files, and the view order is either by file name or by date or whatever, but no custom ordering is ever offered. If the order needs to be a certain way then it should on the users to manage with their file naming OR there should be a completely separate interface purely dedicated to the carousel order (which would again likely be easier to sort and order with a large list of file names and details rather than only ever seeing a handful of small panorama thumbnails that aren’t always decipherable)
  • Allow sub-folders
    There’s no option for creating subfolders, or for having any real sort of organisation to the files. It’s just one big dumping ground. If it was possible to have sub-folders it would help a ton for managing versions or areas when projects get larger, or we want to split the floor plans from the panoramas from the still images, etc.
  • Display Name And File Name
    For many obvious reasons we might want a very specific naming convention for the files/images, however, this isn’t necessary that ‘presentable’ as the image/panorama name when viewed in the live Virtual Tour. When adding hotspots there is an option for a separate ‘Label Title’ to be added to the hotspot icon, however, when you then click the hotspot and go to the view there’s no reference or mention of this label. I would like to propose that the “Label Title” is moved out of the hotspot settings, and is instead included as part of the actual file settings, so that there is both the original file name, and a “display name”. This display name is then used for the hotspot title as well as the view title at the top of the screen when that view is active. The pano thumbnails in the admin/home page area already display Name, Time Stamp, and Comment Icon, so it seems like there could also be a field in there showing what the Display Name is?
  • Auto Hotspots On Floor Plan
    Is it possible to automatically generate hotspots on a floor plan? I’ll admit as soon as I think about this one in any more detail I begin to see all the technical issues associated… But I’m willing to give it more thought if it sounds like something that would be hypothetically be possible and/or has been raised before as a wishlist item??
  • Auto Hotspots By Proximity Not Carousel Order
    This one is potentially similar to the above in terms of being a significant technical challenge, but currently when generating hotspots automatically it’s either “Previous and next” or it’s “All panoramas”. Both of these options are a bit limiting. Once a tour reaches a certain size then “All panoramas” just becomes meaningless and it’s a roll of the dice where you end up cause there’s so many hotspots and they don’t really relate to the current image. “Previous and next” is okay if the carousel order make sense sequentially, but this isn’t always the case, or there are some views that logically split off into 3 or 4 different “paths” and as such want more than just the previous and next hotspot shown. If there was a way to auto hotspot by proximity to the current location I think it could be a pretty big improvement (although I could be convinced otherwise pretty easily), but that brings me to the next item:
  • Auto Hotspots For Current View Only
    Unless I’m missing something, it appears than when automatically generating hotspots it does so for every panomara in the tour? If I just wanted to regenerate or create auto hotspots in the current view only (or a selection of views only) there doesn’t appear to be a mechanism for this?
    This could also solve the “previous and next” issue from the previous point in that if I could Auto Hotspot for the current view only, then it seems like it should be possible to manually select from the list of views which ones to generate hotspots for? E.g. I’m in Room A and I click “Auto Hotspot Current View” and then there’s a list of the views and I can select “View 2”, “View 7”, and “View 11” to all be auto added to this view. And then in future I return to Room A, I bring up the hotspot list, and I just toggle on “View 13” if I need to add that additional hotspot.
    (Of course all of this relies on the hotspots actually being generated in the correct location, which doesn’t appear to be the case currently, but I’ve flagged that separately.)
  • Duplicate File Names Shouldn’t Be Allowed
    Perhaps this is tied up with the upload management system, but when uploading a new file of the same name a prompt is given that the name already exists, and do you want to upload as replacement or as new file. I think the check for the duplicate file name is good, as is the option/confirmation that it will be superseding an existing file, but the option to allow a new file of the exact same name to be uploaded and exist doesn’t make sense to me and causes a whole ton of confusion. Again, thinking of other file management interfaces I can’t think of a single one that allows duplicate files of the same name to co-exist along side each other. I think this option should either be removed entirely, or the duplicate file needs to have some sort of “_Copy” suffix added.
I’m also wondering if perhaps I’m barking up the wrong tree entirely and there isn’t really a future for Virtual Tours as we want to use them? I can imagine that a ton of development resources are being diverted towards AI related features (for better or worse) and it also seems like the 3D Streaming is getting more attention than the Virtual Tours? So someone please tell me now if our energies/workflows are likely better spent else where!
Our issue with 3D streaming/stand alone has always been the free navigation (and I think it lacks VR headset ability?). We don’t always want viewers to be able to navigate around the model themselves - not every one is that good at it and those that are frequently end up in areas that aren’t necessarily ready for public viewing. Being able to set a limited number of locations, and simplifying the navigation to click and drag only, and being able to also view in VR headset without requiring third party apps, is all we really want/need a lot of the time.
Anyways, sincere thanks to anyone who actually reads and responds to any of this. Perhaps these issues are better flagged individually and at the time rather than dumping out months of feedback in one post as I’ve just done, but it takes a bit of time to separate myself from the actual job at hand, to then do testing and confirm behaviour, to then taking screenshots and logging in, to then seeing a new version was released yesterday and I have to do it all again, then actually writing the post in a way that has at least some hope of being understood etc. etc. so these sporadic appearances and novel length threads are all I have.
Hey @Grey_Block !
I have gone trough all of your items, including the other posts.
I will try to update you on all of them here:
  1. Hide/Deactivate Hotspots - I have added an item for this and it should be relatively quickly for us to do. On top of this I plan to add Bulk Edit for hotspots and highlights (long time coming feature) to make managing large virtual tours much faster and less frustrating.
  2. Only Share The Tour, Not The Tour Homepage - As I answered in the other post - it is possible with the ‘embed’ parameter in the URL, but will work on a user friendly way to grab that link.
  3. Multiple Floor Plans - this exists in the system! We had it added a while ago from another customer request. As long as an image is not a Panorama the option exists for each flat image to be marked as a floor-plan. Bear in mind it appears in the image gallery so you may want to put floor plans last.
  4. Scroll in On Floor Plan - You are making a great point - will add an item to enable Scroll Zoom on Floor Plan overlay! Easy fix.
  5. Hotspot Icon Flexibility - We can certainly adjust the parameters to enable smaller sizes. Will add an item for this. Compared to current smallest size - how much smaller do you need them? For the rotation we already have an item. For the custom icons, it will be a bit more work because we need to handle a lot of cases and users being able to upload anything, so this will take more time.
  6. Allow Floorplan To Be A Hotspot - very quick fix - will add as soon as possible.
  7. View/File Management - I agree here. A lot of users actually had requested custom order for panoramas in a tour and hence why we defaulted to this view. You can even today however not reorder items and use the sorting options to sort by file name or upload date. I will add an item to be able to view items in List view as well, probably without a way to reorder in list view at first. We already have items for Compact mode for List View and Grid View - so hope we can get to them soon.
  8. Allow sub-folders - this has some implications for the system, but we have it on the roadmap. For virtual tours - if we added sub-folders - do you imagine this having an impact on how the user views the tour or is it just a tool for the editor to organise the files but when in Present mode - everything is like a flat list of files?
  9. Display Name And File Name - Currently, we do keep the original file name, but it is not visible in the system unless you “download original” file. Do you imagine that in Folder View where you manage the files you have the filename, and you can set a different “Display name”? Currently we only have 1 name and it is both file and display name and it starts with the filename when you upload and once you rename it, it becomes that.
  10. Auto Hotspots On Floor Plan - This is a feature I wanted to have from the start when we added Auto-generated hotspots overall - the issue is we don’t have all the right coordinates for the flat image that you select as a floor plan to enable this today. This feature has to become something that is created as a floor plan from the get go from the Desktop applications (Enscape, V-Ray, etc.) So it will be harder to prioritize for them right now. I will have some talk with other PM’s on the topic.
  11. Auto Hotspots By Proximity Not Carousel Order - I agree the “All panoramas” option is useful only on relatively small Virtual Tours. The question is where you draw the line for the Proximity Distance. We can try to do an experiment about this and see what we can do with the current set up.
  12. Auto Hotspots For Current View Only - We could extend the Auto-Generate settings to allow for that. Will add an item to prioritize.
  13. Duplicate File Names Shouldn’t Be Allowed - Currently the architecture is set up so that unique file-names are not a requirement as we respect internal ID’s that differentiate between files. It is limiting for some users, hence why we went this route. We can add a suffix to differentiate them.
You are right that we had quite a few focus shifts since we released the Virtual Tours and a lot of the updates that we ourselves meant to release got stuck. But we will try to move things along in parallel.
For the 3D Streaming we are also looking into easier navigation methods like click only. The request about limiting the explorable area of a model is valid and we have had it come from multiple users - however it is a priority problem and something that is not implementable by my team but the Enscape/Vantage teams that have to add the ability to create a bounding box/boxes to restrict the user. I will forward that again.
The VR use-case is tough for the 3D Streaming as we need to solve latency and bandwidth issues to deliver the needed quality for a good experience in the headset.
Thank you for the detailed feedback and keep it coming! We are listening to all the active users that want to share requests and frustrations and try to resolve this along our existing roadmaps.
If needed we can hop on a call sometime and discuss your workflows and what we are working on to get early feedback on in-progress features like the Custom Presentations and Whiteboards that I posted recently.
BR
I second alot of his requests. I’m working to utilize this more internally and externally on reviews . People within my company are starting to use this for reviews. They love the fact that we can add pdf’s of all the products within each room for review. No having to go to seperate external files. All contained with here. When will we see the Tagged Colors for specific diciplines. They way Mechanical can filter only there comments . Arch can filter only there comments etc.
