For some reason the split render channels option in the Frame buffer rollout does not put the filename in the dialog when you hit ‘browse’. This is kind of annoying if all you want to do is change a single character for example…you have to retype the whole thing again. The raw image file browse button just above it works properly…so I’m guessing this was just an oversight.
Thanks for the pointer, will check it out.
