Stand Alone .exe File - Resolution Output
Hi guys,
It seems to me the resolution (displayed size) of the .exe file is dependent on the screen size where it is being output.
I’ve done a few tests, and all of the .exe files output from a machinehooked up to 1080 displays, end up looking very pixelated on a 4K display.
The only way I got it to work, was by outputting the exe file from a tower hooked up to a 4k display.
Can anyone confirm, or tell me if I am doing anything wrong.
PS: My workstation has HD monitors, while my VR room has a 4K display. I would say this is stadard practice, since no one REALLY needs a 23" 27" 4K display.
Thanks!
The resolution of the computer that exports the standalone has no impact on the “playback” resolution of the standalone.
However, there is a feature called “Automatic resolution” that might result in what you see. You find the checkbox on the General-Tab. It adjusts the resolution dynamically (every few frames) to ensure a smooth simulation. If you machine is too weak to run in native resolution (in this case, 4K), Enscape detects that and automatically uses a slightly lower one to ensure a high FPS count.
@Thomas_Willberger thank you! This makes sense!
