stepping in emission from curved surface
Hi
i have large curved surface i want to emit from , issue i get is stepping from the grid voxels
im only emitting for 10-15 frames, any technique to eradicate/minimise apart from jacking the grid resolution way high?
cheers
Harv
Hey, the emission will be in the shape of the voxelized surface indeed.
You can smooth it out at render time with opacity mapped by a distance texture using the distance to the emitting geometry like in this tutorial: https://phoenixfd.cgrecord.net/2019/04/making-of-burning-motorcycle.html
Hope this helps, cheers!
Hey Svetlin
Thanks for that, ill try that.
Harv
