Strange noise rendering behavior with GPU
Hello I find an issue when using GPU an Vray Noise or Bercon Noise.
1-apply a noise on diffuse of a cube.
2- rendering with GPU IPR , you only have a blended color, not the 2 colors of the noise.
3- do a final render instead of IPR, you see the noise correct the firsts iterations of rendering and it’s back to an united blended color.
with CPU no issues.
I have came across this and probably forgot to report it
This used to work a while back I think, Both Vray noise and Bercon noise are supposed to be procedurally supported on GPU
Hello guys, the issue is caused by one unsupported mode of the default mapping from V-Ray GPU, in order to use bercon noise you should assign V-Ray UV Channel Named to uvwgen input of the bercon node. It’s a known limitation but unfortunately still not fixed.
Thanks Georgy!
Seems like this limitation is in other V-ray plugins as well, but they usually have a UV channel already with bercons.. probably why I didn’t realize
Thanks again for your help!
That is right, the limitation is not Houdini specific, it’s in the V-Ray GPU renderer and it’s not related to bercon noise, but only the default mapping for procedural textures. I’ll add an issue about that, to change this default uvwgen
Awesome!
thanks Georgy!
thanks Georgy !
