Strange problem with vrayproxies
About vray proxies i have only one 3dsmax64bit that gives problems, becames instable going often in crash other pc with the same file give not the same problem.
But the most strange thing is that seems to can’tload the vray proxy from their path, even if i keep one by one and i reassign the path of the file or i go into the folder and choose it vray npt refresh them giving the geometry as it should be or the cube as it should be it presents only very very little cubes in the scenes strangely positioned and those are the proxyes.
I tryed to reinstall vray, but nothing
Thanks in advance
i reinstalled 3dsmax2009 and vray but the same the vray proxies in sene are not updated
they miss not the path because i go for each one, after seen that by the proper command to strip path to maps and meshes not gaves effects.
Hope in someone help
Thanks and sorry my english
Noone got this problem before :frowning:
Was an HDD problem some files was corrupt without give any error.
I did a chkdsk /f /r to the volume and i overwritten the files of vraymeshes and maps and all returned perfectly at work.
Sorry for the alarm/request
Have good work
