I recently discovered that a Max scene is unable to open, if i had VRAY proxy objects inside and the filepath to that referenced Vray-mesh-proxy has changed during the saving of the scene and opening.
Does someone has the same problem, or is it a conflict with another plugin?
Sorry for late answering - the scene is not opening - at least its not displaying any objects. if you access the Layer-menue all Layer with normal Objects are shown in the List, but not in the Viewport.
I have to copy all regarding Proxies at the exact same location and than it works again.
The reason why i changed pathes is, after a project is finished it goes onto a network drive for backup/archive reasons - but sometimes some parts of the projects are go back into local-hdd for a new project.
Anyway i’m not sure how to work around this, except recreating all regarding file_pathes.
