Sunlight System does not save my location
Hello -
I am experimenting with interior daylighting conditions throughout the day.
Every time I want to change the time, I get the default settings and need to change them all over again (i.e. uncheck ‘Control sun position manually’, sync x-y axis with North, set location, etc.)
Is there a way to have Vray remember these so I could quickly adjust only the time?
thank you
Re: Sunlight System does not save my location
yes, this is a known issue. My recommendation is to save the sun and then call it back to edit it. If you edit the sun, remember to save the sun again.
If you don’t have the save button, you have to update your Rhino RDK.
Best
Thank you!
