I am wondering if there will be a version supporting the latest Skp Patch. In my mind its an important one since they fixed the move/copy modifier that they intentionally changed but listened to the outcry from users and backtracked. The last version was really slowing my workflow down so I updated to this.. but then realized Enscape was not compatible with it.
From sketchup notes “Another undesirable outcome of our 2021.1 release was the persistence of the Move tool’s Copy mode across multiple operations. We decided to address this pain point while also acting on a feature request to make the persistent Copy mode more efficient. For starters, after placing a Copy, the Move tool will revert to its default state.”
@dvsone1440 , no exact info I could share yet when it comes to when we’ll support this new update, but there should not be any reason we won’t be able to rather soon - I have forwarded this to our developers in case they weren’t already aware of this, so thanks a lot for your input and a bit more patience in that regard.
That’s very interesting - We haven’t had a look internally ourselves whether or not this version works just fine but, perhaps you could try simply re-installing SketchUp + Enscape @dvsone1440 to see if that already does the trick for you too? Perhaps this is a simple case of Enscape not being installed properly (for whichever reason) anymore after the update.
When I tried to install it Enscape menus would not appear. It shows enscape in the Extension manager and says its on but nothing so I assumed it was not compatible.
Yes, I did try and enscape menus were not loading. I just assumed it was not compatible but maybe it was a different issue Maybe I will just try reinstalling everything again
Yah I installed the new skp Then the new Enscape. THat did not work. I am going to try to reverse that and install an old version of skp then new enscape then new skp.
I am having the same trouble again. 3.2 does not appear in my skp 21.1.332
Last time we had to install an old version of skp then install new enscape then install new skp I think to make this work. Does anyone have any idea what’s going on with this?
