I have two windows 10 machines (one workstation and one macbook pro running bootcamp)
I have Swarm and vray installed on both. I can successfully open the Swarm UI on both machines with both machines being listed as ENABLED.
I can successfully ping one machine from the other.
But when I try and render wtih Swarm on, Current usage stays at 0% (even though goal is set to 100%), and the buckets don’t seem to show the slave machine, only the host processors.
Network discovery is set to Auto-Discovery.
When I upgraded to vray 3, I only got the base package with no extra render nodes (I thought 1 was included in the price). Do I need to purchase the extra nodes to even use 1 machine as a slave?
If not, is there anything I else can try to get them to work?
Thanks,
Andrew
