System Unit conversion
Suppose you have pre-rigged models done in 1 system unit scale and you need to bring it into a scene set to a different unit. how can you rescale characters to avoid the mess
We have done the following with characters and it has seemed to work every time:
- open scene file with character, change units to desired scale; save scene.
- open secondary scene; merge in character.
This should work. Just make sure that when you save the character, you are saving it with the same scale as the scene you are merging it into.
Hope this helps.
that doesnt work. when you change the system scale from 1 unit = 1 meter to 1 inch then the character is too small
Ah ok… what about just linking everything to a dummy, and then scaling the dummy up/down? That way you can scale up/down as much as you want.
did you try the global utility “rescale world units” ?
Am not sure how it behaves with complex rigs but for some things i tried it worked rather well.
Regards,
Thorsten
i changed the system units, then tried glabal scale and the dummies in the rig were screwed up
In this situation I…
Pointcache
the character in one file and then scale the point scaled mesh with the rig removed (delete Skin or Physique from the stack). Works a treat if you don’t have to interact with too many objects, even then you can bring just those objects in an animated to them and then just us a dummy for your scaling to get them to fit.
The Point cache replaces the need for a skin modifier and scales nicely.
Cheers
Mike K
it was totally simple. i just went into the structure of the biped and reset the character to the right height
All hail the evil master of the interweb !
cooooooool. DOH!!! not its changed. but it shall forever be immortalized in this image. thanks tammo. Im surprised that ive been able to hold on to at least 3rd place for post amount. i remember when i held 1st place for a long time way over Vlado. but now Vlado rules supreme as he should.
yes, well we all kind of come and go at times, but vlado remains constant. good thing too!
haha
agreed. dont know what we would do without him… but great image regardless…=P congrats da_elf…
i think there should be a new descriptive scale. im probably a little or a lot older than a senior member. what was the name of the forum we used to use when we were alpha testers before vray hit the market. ahhh those were good old days. i remember when incremental irradiance maps were first introduced. and the first incarnation of motion blur. fun times. ive still got some of the alpha copies on my hard drive.
Yes that was an interesting time.
I remember my first try with GI animation and it was flickering a lot.
It was a rotating box above the ground and i thought the flickering was some kind of bug and easy to fix.
Then we asked vlado if he could make vray able to load animated textures that we needed for a music video before running into the deadline.
He made it of course.
A genral rule of thumb I use is never touch the system unit scale so it stays in inches, since most people don’t touch it either
i dont normally touch it. however others do touch it so i needed to get their stuff changed
This is what I used to make this work. Hope it helps.
http://www.axyz-design.com/3d-animation-human-character-model-documents-tutorials/aXYZ-User-Guide.pdf
Regards,
Mike
anyone ever tried to rescale the marsha model? her eyes and teeth are linked to the head bone so when i re-structure the biped to the right height the eyes and teeth wont be resized
speak for yourself. Over here (SA) and some places in Europe they always set it to either cm or mm. I use to set it to mm but lately seems people prefer cm for system units.
I then set display units to either mm or metre depending on the project
