Test interior
That’s only test so that have alot of broblem. And i think you can help me to answer the question :
This PIC have some noise in somewhere,and what is true cause? light cache too little ? ( LC 800 because is only Test) or Subdips of Light ( rectang light and Sky Imviroment in scene ). I can’t Test with LC too hight because it take alot time. This pic 800X500 take me 1h. Thank you ! ( Sorry that my english too bad )
Re: Test interior
i like the glass of the table whats the setting of it??
Re: Test interior
i have a little experien that : With glass material i allway use Sketchup tranparency not import anything vraymaterial. I hope that useful with you.
Re: Test interior
u can try to use QMC for the image sampler and then if u want reduce the value of the noise of you QMC. HOPE THAT WAS HELPFUL.
Re: Test interior
Devinci,
I like your graphics on the wall. make your IR multiplier higher. Also put invicible rect light on the window to make smooth the walls.
Re: Test interior
Yes ! I did by that way !
Re: Test interior
check if your primary engine is ‘Irradiance Map’, i think it will to get rid of that noise.
The glass on top of the coffee table is looks grate.
