Texture Bake with DR error
My DR setup is working with normal renders. My texture baking is working for non-DR renders. However when I try to render to texture with DR I get this error on the render server:
UNHANDLED EXCEPTION: Rendering image
Last marker is at P:\dev\LocalVSS\vrender\src\vray.cpp, line 1318: Vray::getMaxBgColor()
I am not using the VR frame buffer because I’m only rendering a “complete map”. I sent the log file from the render server to vray@chaossw.com
