Hi, I have been trying to “render to texture” and keep getting this error. Can someone point me in the right direction? Thanks a lot.
Here is the Vraylog text file as well.
Thanks in advance
vraylog.txt (92.9 KB)
[2018/Aug/9|20:05:03] warning: V-Ray VFB is enabled but no save option is selected - baked textures will be lost.
[2018/Aug/9|20:05:03] warning: Please select a VFB output option or use the 3dsmax VFB.
[2018/Aug/9|20:05:05] Tracing 250000 image samples for light cache in 64 passes.
[2018/Aug/9|20:05:07] Light cache contains 23 samples.
[2018/Aug/9|20:05:07] error: UNHANDLED EXCEPTION: Rendering region (992,1024)-(1024,1056)
Something may be wrong in your setup.
Have you tried resetting the render settings?
Does it render fine if you do not render a region?
Could it be that you used max default maps instead of the Vray ones. Like “Complete Map” instead of “VrayCompleteMap”. This usually causes unhandled exceptions when baking textures.
I do this mistake almost every time I need to bake textures (1-2 times per year ) it would be great if Vray can hide these incompatible maps .
Wanted to say thanks a lot for the advice. I didn’t have time to troubleshoot more but will get back to it.
