one aspect that annoys me in 4 out of 5 times when working with enscape or when watching the images shared in the forum is the quality of the textures in the renders…
it was said that “in time” there will be a better technical solution but as of now it looks still like in the early days and that is all textures get downsampled to 2 k automatically…
with the new gpus and the amound of vram and solutions like texture streaming its about time dear enscape team to tackle this issue… i get that for VR we need to have a fast approach but fore still renders, videos and display presentations we also need some more beauty..
so if no automatical solution is feasable fast, you should give useres the option to set the downscaling factor in respect to the input images..
the downsampling to 2k is gone for several releases now. We’re now evaluating the scale of the textures in the scene and only do downsampling if the resolution is vastly too large for it’s usage (e.g. using a 4k texture for a piecer of paper) or if we can’t fit all the textures into your graphics card’s memory.
Do you have an example where you think your textures get downscaled too aggressively?
@comcasa good question! Actually yes, depending on the resolution and the number of textures we need to resize this might add substantially to the loading time.
As we speak, we’re optimizing this for the next release to run in parallel, so that you can navigate through your model while textures are still beeing processed.
But if you know beforehand that you don’t require the textures to be in full resolution you can downscale them before hand and this will definitely speed things up either way. If you look into the log files (%AppData%\Roaming\Enscape\Data\Logs) you can actually see which textures are getting resized to what resolution.
