texture
Hy guys,
sorry for my english.
I have problems with the texture: I want to insert a logo like from attached image, but: 1 is repeated many times over and I want to insert it once single, in a determined point (on the angle). the 2 texture on the curve are ironed. I have used various methods, but with insufficient happening, you can help me? Use vray from little time, I have always used cinema4d and these operations were more immediate
Gianluca
Re: texture
Select your object and go to object properties → “Texture Mapping”. Add a custom mapping channel and then select the mapping type that you would like. You can pick tiling and all that stuff from there using the RDK mapping tools.
