The Cosmos Browser wont open
The error is the following: ===== Error(97) =====
Can not open the Cosmos Browser, because Cosmos Service is not running. Everytime I uninstall and install it again it works once, but when I close 3ds max, the next time I open it, the Cosmos Browser won’t work anymore, and is always this same message. Havent found anything about this specific error
Please try this:
  1. Close 3ds Max
  2. Run the Corona installer again and reinstall Corona
  3. Open the Start menu, type “Stop Chaos Cosmos” and run the “Stop Chaos Cosmos Browser” item
  4. Open the Start menu, type “Start Chaos Cosmos” and run the “Start Chaos Cosmos Browser” item
  5. Check if it works correctly now
If it doesn’t seem to work, please contact us at https://support.chaos.com/hc/en-us/requests/new and a dedicated team will help you.
Hello, did you have any success with starting Cosmos?
Hi maru,
had the same problem in Corona 10 RC 1 and Cinema 4D 2023.2.1 in Win11. Your hint works for me.
regards
