the photometric light of 3dsmax not using ies web profile.
Please support the photometric light of 3dsmax not using ies web profile.
Because the Production render side is supporting it, its result does not match with RT.
Thank you.:hushed:
It is marked to be solved; but out of curiousity, can you tell me why you use a photometric light without a profile?
It is a case where the rendering of the scene created mentalray or for scanline is done.
Although there is also a method of converting photometric light into vraylight, the vray scene converter does not do it.
VRayLight will be used when making from zero, of course.
Thanks so much :slight_smile:
