The specified procedure could not be found.
Hi, i try to run V-Ray 2.20.01 (vray_demo_22001_maya2012_x64.zip) with Win7/Maya 2012 x64 and from custom location.
And i got this error:
// Error: line 1: Unable to dynamically load : C:/vray/demo_2012_22001/maya_vray/plug-ins/vrayformaya.mll
// Error: line 1: The specified procedure could not be found.
 (vrayformaya) //
Any help ?
thx
Did you set the PATH environment variable to point to maya_root/bin folder from the .zip archive?
Yes, I set it. :frowning:
This is my batch start.bat
@ECHO OFF
SET MAYA_LOCATION=C:\Program Files\Autodesk\Maya2012
SET MAYA_RENDER_DESC_PATH=C:\vray\demo_2012_22001\maya_root\bin\rendererDesc
SET VRAY_FOR_MAYA2012_MAIN_x64=C:\vray\demo_2012_22001\maya_vray
SET VRAY_FOR_MAYA2012_PLUGINS_x64=C:\vray\demo_2012_22001\maya_vray\vrayplugins
SET MAYA_PLUG_IN_PATH=C:\vray\demo_2012_22001\maya_vray\plug-ins
SET MAYA_SCRIPT_PATH=C:\vray\demo_2012_22001\maya_vray\scripts
SET MAYA_MODULE_PATH=C:\vray\demo_2012_22001\maya_root\modules
SET XBMLANGPATH=C:\vray\demo_2012_22001\maya_vray\icons
SET PATH=C:\vray\demo_2012_22001\maya_root\bin
"C:\Program Files\Autodesk\Maya2012\bin\maya.exe"
It’s solved.
There was problem with one version installed in system. I uninstalled it and it’s working.
raxto
Ah, good to know. Yes, if you have V-Ray installed locally, it will interfere with the other version you are trying to install.
