Vray 5 beta doesn't load in Maya 2022
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pluginWin.mel line 316: The specified procedure could not be found.
(vrayformaya) //
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pluginWin.mel line 316: Unable to dynamically load : C:/Program Files/Autodesk/Maya2022/vray/plug-ins/vrayformaya.mll
(vrayformaya) //
The solution to removing Maya 2020 from the system environment path so that only Maya 2022 is in there does not fix the issue.
This is the May 27th nightly stable build
