Whether this option is turned on or off, it will not have any effect on the scene
Hello @123456_1
Thank you very much for your time and efforts to provide the necessary information to replicate the issue on our side. It is classified as a bug (VC4D-1940) and escalated to the Development team for further inspection and resolution.
I will reach out to you once more information is available.
I looked at version 6.2 and it seems that the options are locked and cannot be clicked, and there is no lighting generated
Hello @123456_1 ,
This option will be active if you disable the GI. You can then enable or disable the default light. Please give it a try and let me know if you have further queries. Thanks.
Thank you for your guidance. I have successfully used this feature, but why do I need to turn off Gi to use it?
The reason for this is that V-Ray doesn’t have default lights when the GI is enabled. The default light only gets activated once the GI is disabled. I hope this makes sense.
Can you modify this feature to enable default lighting only when there are no lights in the scene, instead of checking if Gi is enabled? Because Vray defaults to enabling Gi, it means that this feature is not enabled by default
Hello @123456_1 ,
Please note that this feature is intended to work like that as there are no default lights in the scene when the GI is enabled.
