The light seem
s to be making things shimmer and very blurry. anyone know a fix for this?
Welcome to our Forum.
It’s a bit hard to see what kind of lights / light sources you’ve setup in your scene exactly, but please definitely make sure that you are mostly making use of lights instead of emissive surfaces. Using only self-illuminating / emissive surfaces will usually cause these artifacts you see in the project, but adding actual light sources instead should help.
What CAD solution are you using with Enscape?
And thanks a lot in advance for any further replies.
This project is in Revit using light sources. I have tried a few different lights with the same results.
You can gladly send me the scene as well (and use wetransfer.com for uploading as an example) as it’s not easy to see what lights are placed exactly where and so forth.
Also, you do not have any emissive surfaces in your scene at all then? Does it make a difference if you place more lights to brighten the scene more evenly or not at all?
Last but not least, make sure you’re using our latest release and also that your graphics card drivers are fully up to date.
Thanks again in advance.
