Since updating to Enscape 2.7 I have been experiencing a strange phenomenon when rendering night images with artificial lighting (attached images). Apparently artificial lights reflect some kind of flash in a circular shape. Has it happened to someone else? how do I solve it? It had not happened before in previous versions, this is the first time. Thanks in advance.
Hi @Jeanvo90 & welcome to our forums!
Thanks for your report. We’ve had similar ones from two other customers before, that had a very similar problem after upgrading to 2.7. We’ve since then identified the source of the issue based on their provided project files and will ship a fix in the upcoming 2.7.1 version, which should be released next week.
To make sure that we’ve got your case covered as well you’re welcome to submit your project file to our support (please contact @Demian_Gutberlet in a direct message to discuss details).
In the meantime you might want to try and see if it helps to reduce the brightness of your light sources.
Hope that helps! ![]()
