Learning FastSSS2, I found myself with this:
Here the scene:
Its a bug?. I don’t understand why appear almost the scatter color like gummybear foot reflection… or something more circular.
FastGummyBear.mb..zip (69.1 KB)
Here the scene:
Change the “Shadow bias” for the lights to a smaller value (e.g. 0.001) and it will be fine.
I got it. Thanks for the trick.
Eeeer, yes it works, but if we put the “Single Scatter” in “Raytraced (refractive)”… this remains. How we can solve it then?.
And the most important. How ever, Why?. Why this happens?. I we know why, we can avoid “being fixing errors”, because directly we don’t fall again in the same.
did you turn off the shadows for all the lights in the scene ? I’m seeing two lights in scene, turning off shadows for both of them and the artifact is gone for both simple and refractive modes.
Also modifying the shadow bias fixes the problem, like Vlado said, irrespective of the VRayFastSSS2 mode.
The shadow bias is there, so that artifacts (surface acne) are not present when there are overlapping surfaces in the scene. Unfortunately, depending on the scene scale, artifacts like in your case may occur. Probably we need to lower the default shadow bias value, I’m not sure. Vlado can say about that.
Greetings,
Vladimir Nedev
Incredible. I was me who created the test scene and I’m unable to see that I created two lights… bless patience you should have with us (me, in really, what’s auto owned!). Thanks for the hint one more time.
