Threadripper 7995WX 96-Cores
Windows 11
3dsmax 2016
Vray 3.60.04
My first test render has 64 render buckets. Does this sound right? I’m not sure if hardware/Windows is limiting cpu access or it’s something on vray’s side of things
Anyone else run into this?
I have a Threadripper 3990x (64 Cores/128 Threads) and it shows 128 Renderbuckets.
So in your case you should see 192 Buckets.
It is a combination of both. Windows has some specifics about supporting more than 64 cores so it needs explicit software support. We added it in V-Ray 3.4.
Later on Windows 11 changed a bit the way more than 64 cores are handled and it required software updates again. This was added in V-Ray 5.2
Yavor
Thanks for the response @yavor.rubenov -- does this mean if we installed Windows 10 we could fully utilize the cores with V-Ray 3.6?
Overall V-Ray 3.6 is quite old so I can’t really say what would happen - try at your own risk..
Good news, IT was able to modify Windows 11 to take full advantage of the cores with Vray 3.6
Here’s what we did if others stumble on this --
I edited the registry and added the DWORD SplitLargeNodes to Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\NUMA and set it to 1
The VRSpawner.log (%temp% folder) initially was showing one processor group in the ‘group aware processor detection’ -- once the above change was made, three groups were detected and all cores were utilized for rendering
Kudos to your ITs. I didn’t know there was an option for that..
