I lost the vray toolbar after installing phoenixfd nightly. It happens often in the past that I lost the vray toolbar. Normally I just reinstall vray, but this time it does not reappear. I hide and unhide it by right clicking a toolbar and it does not reappear. I go in custtomize user interface and click hide et unclick it ans nothing do it.
Maybe it would be better to include do a vray ribbon tab. I think they are more stable.
Ok. It may be due to other plugins interfereing. But that always happen only with vray toolbar. It happened sometimes in max 2014 to me but reainstalling vray fixed it. But now even when resintalling it does not come back. Anyway I created a tab in the ribbon for my vray shortcut.
Can’t reproduce it using the same versions here. Could be related to other plugins installed, but can’t be sure about that because I have few here that creates additional toolbars.
Which 3DS Max workspace you are using ? What about if you change it and restart 3DS Max to take its effect?
We don’t have such issues on our machine where the same plugins are installed. Those plugins should not have any impact to the new V-Ray 3 toolbar.
What are the Ornatrix & Forest pack pro versions ?
I was using the max.vray defaultUI and I changed it to modular toolbar and then the vray toolbar reappeared. I then went back to default ui and the vray toolbar is there. so it did the trick! thanks!
I now have this problem where I can’t get the v-ray toobar back!
I had a problem with the “Selection Filter” tool-bar pull-down item, which showed up blank. The only way I could find to fix this was to change the UI in the Custom UI and defaults switcher. When I changed that to “MAX.vray” and “DefaultUI” I lost the v-ray toobar. I have also noticed that when I load a Custom UI scheme the v-ray tool-bar dissapears, but there is a very simple way to fix both situations… When, after making a change to the UI in any way, it tells you that you will need to re-start Max for the changes to complete, it really means that, and when you re-start, the v-ray toolbar comes back.
