I heard that you can only use it form the tool bar but for years my Vray toolbar is corrupt. ( I don’t think that the way to solve this is to reconstruct my 3dsmax.ini file. sorry Chaos - ! You should find a way to solve it differently)
If you don’t want to follow what is advised, then just create your own toolbar with the buttons that you need, that still works.
Hi
Actually I did and it did not help. for a blimp it appeared and then gone. All I get is a long empty toolbar and the tooltips are like “$#@^” or similar. It has happened before.
Regarding creating my own toolbar - I tried but the command for the unified lister does not appear there. Watch this short video:
What you see in the video is AFTER doing so.
Is your V-Ray installed in an arbitrary location? If yes, you must do an additional step described at the bottom of this page.
My Vray is installed on my only workstation. I no longer use slaves. my 3ds max is on c:\3ds max 2021 when installing I do not modife anything.
Have you tried these suggestions by Autodesk?
I will try it . However - It says there that the toolbar is still active - In my case - It is not and the tooltips show a sort of Gibberish.
