I am having difficulty with toon material. There is a big rectangular light just at the front of the section. If I apply toon material to whats behind it ie walls a big line across the entire light appears.
Any ideas why ?
Thank you !
Kindly note that this is a known issue and it has already been logged, however, there is no ETA when it will be resolved.
This occurs with invisible V-Ray Mesh, Sphere, and Rectangular lights when they are in front of an object with Toon material.
As a workaround, you could use a V-Ray SpotLight or V-Ray Omni Light.
Thank you ! I was struggling with this issue for a long time and could not find an answer. As you can imagine its much faster and easier to use rectangular lights to light up big chunk of the scene evenly. Toon very often used for quick studies as the edges are more defined by the toon lines created.
Best,
J
