I’m testing the implementation of the toon shading in Vray for houdini. For some reason i can’t succeed to have the outlines working.
Config: Houdini 20.5.684, vray 7.10.1
Any ideas?
Thanks,
Carine
Hey @carineg ,
Our QAs did a quick check, and our internal tests using the toon effect/material appear to still work - I’m guessing it might be a specific setup that we have no test coverage for - could you please ZIP your HIP file and upload it for us to check?
Thank you!
I succeed to make it work by activating (on top of the others toon workflows )the “enable toon” in the display option of solaris viewport while overriding them with the rendersttings of my scene (so the check box has to be ticked while it’s grey/frozen). I saw later that there is also another similar check box as well in the viewport tab of the rendersettings node. It’s a bit confusing on which viewport display is overriding the other one. Maybe there’s something to simplify there and also to notify in the tutorials ![]()
If you still want the scene file let me know.
Thx,
Carine
