Hi there, I have a toon shader environment element and it works well, but it’s not turning off unless I delete it from the Environment.
Is there something I’m missing?
See the image attached.
I guess you are not missing anything, have to fix this…
Dear @chadstevens , hello.
You are using our latest stable build, I checked.
We have encountered some issues with Toon, but disabling is achievable in our tests with the same build and with latest nightlies.
Could you share a simple scene (.zip is uploadable here)?
It will be highly appreciated.
Maybe some detail in your setup is disturbing the disabling.
We have to be sure.
Thanks in advance,
TS
Seems to work fine for me with the nightly build…
Hi, Sorry for the late response, it’s been a busy few days.
Still have the issue on my side, even once I restart Houdini it still has the toon shader enabled.
ToonError.zip (111 KB)
I’ve updated to the latest nightly build and the problem went away ![]()
Thanks for the help.
Thanks for sharing.
Enjoy V-Ray & Toon.
