toon shader - toon edges override bug
Hi there,
Another fun one. As soon as I plug an input into the bump slot of the vray toon shader, the toon edges override does not work anymore, reverting to default.
Even if the bump mult is 0.000 the override does not work.
Vray v5.00.20 for maya 2020.3
I took a lot at this problem and was able to reproduce it. I have logged an issue, which you can track with this internal bug tracker ID: VMAYA-10024
Great, thank you!
