Total Darkness / Night Sky Not Visible / Lights Very Dim
We have been using SketchUp Pro + Enscape for, I believe, just over a year now, and we have become very accustomed to manipulating the plugin and it’s many versatile options. We are a design firm specializing in high-end residential outdoor environments, so it’s typical for us to show several day time scenes, followed by afternoon scenes, and then several night time scenes with lots of lighting elements. I’m well versed in the atmosphere settings such sun brightness, ambient brightness, night time brightness, synthetic light brightness, etc. We have often changed these settings from model to model, and even from scene to scene in order to get the lighting just right for each shot. But as of today, something seems very wrong and I cannot figure out what happened or what changed.
Traditionally, I have adhered closely to most of the standard brightness settings, and when I include lighting features in the model, I typically don’t have to set their individual illumination values above 30 - 50 points. When altering the time using the short cut keys (U + I), there is always a smooth transition between day, afternoon, and night. The natural light dims, and the synthetic lights come on and slowly get stronger until the sun is completely gone. And once night time arrives, you can always see the stars, the clouds, and especially the moon.
Right now, when I get to a night time hour, the sky is completely dark. All surfaces are dark. It’s as if there is zero ambient brightness or sky brightness during night time, even if I slide all of the brightness settings to their maximum value. I cannot see stars, or moon or clouds. And in order to see any of the synthetic lights, I have to change their individual illumination properties up into the 10,000 - 100,000 value region on the slider scale.
Something is very wrong here, and none of the visual settings seem to be having any effect on this problem. Please help!
***EDITED: I have added some screen grabs to show what I’m referring to. The daytime light settings seem to be behaving like normal. It’s just the night time lighting that is not performing as it usually does. Also, in case anyone is curious, The purple lights in the foreground are individually set at about 1,000cd. The purple lights off in the distance are raised up higher and are set at about 500cd. And the fire material off to the left is a self-illuminated material set at 100,000cd. None of this is displaying correctly.
Hi @BradatRAD
I’m sorry to hear this.
I have responded to the feedback you have sent and I am looking forward to your reply there.
I guess You tried as well turning off auto-exposure.. Maybe there is one not standard ies file which is much stronger then others and ENS is adjusting to it.. just thinking.. try maybe copy everything to new file and check on default settings to ensure it is not some file error.. … rather useless comment..
Our office is having the same issue. The night sky is all black.
Hi @Ryan_Group
Welcome to our forum.
In this case it was as @tomasz_drgas suggested that the Auto Exposure setting was turned off, please try either reactivating this setting again in our Visual Settings under the Main tab, or increase the Exposure percentage manually there.
