Hello
I’m trying to exclude a Vray light from being reflected on a floor and keep its reflection on the other objects using trace sets but it doesn’t seems to work anymore .
I’m using a script to do this as Max doesn’t show lights in trace set list and when I open the list I can see my light in there but in render it doesn’t work .
I’m pretty sure I did this years back but I can’t recall on which version
I’m using Max 2016 and Vray next 1.2
Here is a screenshot for the problem .
Any thought on this?
Hello
I’ve tested this with VRay 5.0 and it is still not working .
is there any plan to support this again , please?
Not promising anything, but I’ll bump the issue (internal bug-tracker id: VMAX-8978 ) on your behalf.
Thank you !
I’m sure many will appreciate a fix for this too .
