http://static.flickr.com/82/213882714\_d8f1067c72\_o.jpg
Take a look at this iamge. I want to make the shower curtain more translucent. I should be seeing some detail through the other side.
Any ideas about how to creat a translucent material?
look in the manual under the section of vray 2 sided material. that should give you the results you want im guessing
Yep, I used it on some curtains. Looks great.
translucent materials
I dont see the vray 2sided material inthe material/ map browser. I see the vray material and vray light but novray 2 sided. what am I missing?
If you want to see trough the curtain, I would use only refraction with some subtle glossiness.
You are missing 1.5?
Yes refraction - or just opacity map with some falloff.
