Hi - what’s the best way to render with a transparent background?
I usually just subtract the alpha JPEG in post-production but I’m sure it would be crisper if I was able to just render without the background?
Thanks,
Jack
Save your rendering in PNG format and you should get the transpanernt background.
Hi @jacksivyer ,
Another thing you should consider is rendering upon a black background and saving as an .exr
Otherwise you might see issues like the following:
Here are the steps that would avoid aliasing issues and give you perfect results:
1. Ensure that the background of your final render is black.
To keep the lighting and reflections you can use the other environment slots:
3. Open the exr in Photoshop and load the alpha as Transparency
4. Continue compositing in 32 bit mode or change the image mode to 8 bit (Image > Mode > 8bit/Channel)
Regards,
Konstantin
