How to save the rendering without transparency, so that the background is kept?
I have to render a lot of images and I want to keep the background visible, no alpha should be used for the saved image. How can this be done?
-Micha
I’m still looking for a solution and I found the old thread here:
An other example where an disabled alpha is needed, if some one render an animation (for example per Bongo) and like to get the background at the rendered frames.
I would be very glad if a solution could be found now without to need to beg for an answer/workaround/solution anymore. Please try to solve the tiny task.
I think it depends on the output file format you are using and the lighting system (vray sun + vray sky or hdri, etc)
Apologies for the late reply!
The old forum topic you have referenced provides the working solution!
In the Render Output > Save Image > Image Options > Alpha parameter, you can set No Alpha
