Transparent VRaySoftbox Grads
Hi
Is it possible to have Transparent VRaySoftbox Grads, instead of the gradient to black?
Cheers
You can plug the softbox texture in the opacity slot of the material (if you’re using a mesh plane) or in the Rect Tex A slot of the rectLight (if you’re using a rect light). In the case of the rect light, you could save yourself a bit of trouble in the connection editor if you just put the softBox in a luminance node, which you can then plug into rectTexA. RectTexA is actually the alpha of the rect light.
Great, thanks Alex.
