Is it possible to link a curve (remapValue) in to the Horizontal Gradient slot on the VRaySoftbox?
I would like to create an inverse square law curve for the light.
Maya’s remapValue slots in to the Horizontal Gradient’s position, colour and interpolation by the looks of things, but I can’t see a slot for the ramp.
I’m not sure I understand this, could you help me out a bit? Where do you need to plug in a remapValue exactly? The Horizontal gradient is like a ramp - when adding new positions, you can plug in anything to their value (color).
Well, most of things that are possible about how a regular ramp behaves should be possible with the softBox gradients. In fact, the control is similiar, if not the same, as any ramps available in other nodes.
You can plug a remap between the texture and the gradient’s ramp position, just like in any other ramp, if that suits your case. But you can’t plug the remap after that.
Here’s what I mean - you can plug a remap or a remapRamp (from texture > effects) and then plug the result in the horizontal gradient. I don’t know if that is going to work for you, though.
Hmm, Maya seems to expose those only when they are connected. I’ve basically connected the textures to the color of the gradient positions in the attribute editor - then they are exposed as inputs in the node view like on my screenshot.
