It would be very nice to have triplanar mapping implemented directly in CoronaBitmap for easier set up and more convenient use. I guess that due to lack of UI space, triplanar in CBitmap would have to be simplified, so separate triplanar node should still be available for full features access and for backward compatibility.
It seems that Fstorm has already such feature implemented, as it can be seen from image below.
Scale control should be definitely implemented. Rotation and offset probably could be considered as advanced features and only available in dedicated node. Image in the first post, is from Fstorm implementation, it does not imply that Corona team should follow exact implementation.
You just drive it using tiling like you would a normal bitmap but it also drives Triplanar. I enable real world scale most of the time. Works really well.
denisT.MaxDoctor offered some code support in response to the suggested implementation, which you can see here, although it doesn’t appear that the code satisfies the proposed feature request, exactly.
The Fstorm implementation is a good solution, however a script-based solution might function differently and I have outlined a workflow below:
The idea is that the user sees a material with bitmaps attached in the Slate Material Editor (see ‘before.png’), selects the material, clicks a button (or hotkey), and then sees that material with triplanar nodes inserted, and bezier float controllers attached to the ‘scale’ parameter of the triplanar nodes (see ‘after.png’).
A material with triplanar nodes inserted between the CoronaMtl and incoming nodes. Bezier float controllers are attached to the ‘scale’ parameter of the triplanar nodes to globally adjust triplanar scaling.
NOTE: triplanar node in the bump channel is inserted between the Corona Normal Texmap and the material, rather than between the source bitmap (normal) and the Corona Normal Texmap.
Did we ever get any feedback from the development team on enhanced integration for the Corona Triplanar Map? It seems like the FStorm style integration in which triplanar mode is folded into the Corona Bitmap is a strong suggestion.
