Triplanar Normal map problem.
Having an issue with the way vray is calculating highlights when running the normal map texture through a triplanar node.
First image is using the surface’s UVs; the result is as expected.
The second image runs the same normal map through a triplanar node; the result is the highlights are not rendered correctly.
Is this a bug or am I doing something wrong?
Could you tell us in more details why do you think the there is an issue with the highlights when using Triplanar texture and what exactly do you expect as an result.
Please note the that the VRayTriplanarTex works by projecting one or more textures along the object-space axes of the object.
As you can see from the graph, both are using the same texture map…the only difference is the triplanar node and a bit of scaling added to the second render.
The way that the scratches are being lit should be more or less the same in both images, but they are not.
The texture is random lines going in all directions. I am trying to simulate the micro-scratches you might find in car paint.
Reference image: http://www.autogeekonline.net/gallery/data/836/redelcamino\_029.jpg
In the left UV mapped method, the scratches are being lit in a circular pattern around the highlight; this is correct.
In the right triplanar mapped method, the scratches are lit in a star-like pattern radiating out from the center of the highlight; random scratches would not look like this.
Thanks for the details. I think I got what you are saying but it would be best if you could send us your scene in order to reproduce the same results here.
i have the same issue here, im not sure triplaner works very well with normalmaps tbh
thanks
matt
Thanks for the feedback. Unfortunately the issue with the normal mapping producing strainge artifacts is still unresolved.
Attached is a Maya 2018 file of the above example.
If my idea is correct, then to fix this means triplanar would somehow need to reference surface normals for projection direction for a more cube-like projection.
triplanar_scratches.zip (2.46 MB)
Thank you for the provided files. I will take a look and I will report to our Dev Team what you have found.
its a shame this is still not fixed even in vray next, it would be really good to use normal maps and vray triplanar
Dear Vray Developers,
I can still reproduce this problem right now. I made a video showing the problem. In the case i am not doing something wrong in the shader setup in maya, this seems to be a bug with VrayTriplanar.
Here is the Video showing the problem:
This feature is working completely fine in the 3DsMax Version of the Vray Plugin with the following nodegraph:
As mentioned in the Video the Scene file and the normalmap are attached to this post. If I am not doing something wrong. Please fix this bug!
vray_triplanar_maya_testfile.zip (3.26 MB)
did anything get resolved with this?
still does not work with Next 4.3
here is the reason why it does not work, or does it work? how can we convert tangent space normal into screen space or world space maps?
https://medium.com/@bgolus/normal-ma…r-10bf39dca05a
The triplanar work just perfect !
Should work.
Can we get a definitive yes or no whether normal maps and vray tri-planar are working correctly? Ive had some conversations that suggest it is not working properly. It renders, but once you dig a bit deeper, the normals are doing weird things.
Hi Chaos,
i also would be interested to have a definate answer on why this does not work from the vray devs. Come on guys lets finally put this disucssion to bed.
thanks
matt
bumpybump?
Come on vray Devs, a response would be honorable…
Or perhaps @lele can you at least derail this one for us
Triplanar maps should work with normal maps, yes. Make sure you set the size/scale parameter correctly.
On meshes without any UV sets, normal maps can show seams, since we need proper UVs to build continuous tangent space matrices.
If that’s your case, using bump might be less problematic on these meshes.
Hi @Mihail_Kuzev_1
Sorry but i disagree with you
Do you think this is expected behavour for vraytriplanar and a normalmap on a simple cube, There are 6 lights one on each face, for me the normal map is only working correclty on face 1 and 6.
I have also attached the scene and textrure for you convienence, please load it in maya 2020 latest vray and let me know if this is expected behaviour or a bug or not the intended use of triplaner and normal maps. (if the latter maybe can all have a definate answer from you that it doesnt work and do not use it for normal maps)
thanks in advance
matt
tri planer issue.rar (1.21 MB)
So what’s the problem, is it concave/convex mixed up?
