As described in the title.
I followed this help tidbit at the bottom of the help doc on Triplanar Texture “If you wish to use a VRayNormalMap with VRayTriplanarTex in a material, assign the VRayNormalMap to the VRayTriplanarTex texture node and then use the VRayTriplanarTex in your material. Linking in the other direction is not recommended.”
However, this does not work.
