Trying to work with ACES and exr. Having some gamma issues.
Still trying to learn my workflow and I’m having some gamma issues when saving to exr and opening in Fusion. Working in ACES color space.
If you look at my image on the right is VFB in max and the left is how the image opens in Fusion. So not sure what I’m doing wrong with my settings. I have Display Correction setup for OCIO using aces_1.0.3.
Thank you for any advice.
Could you please upload the EXR here? And how do you save your EXR, do you render to disk or save from the Frame Buffer?
This is most likely an issue with your Fusion setup I think,
On another note, make sure to use this 1.2 ACES version here
The version you have 1.0.3 is very old and outdated
Best,
Muhammed
