In this video - I show you what you should enable in the settings - to render 100% of the hair, while in the viewport was 1%. In the tutorial I use Ornatrix 3ds Max and V-Ray 5.
CONTENTS:
0:00 - We see that in the rendering there is no 100% hair, when in the viewport there is 1%. How do we fix this?
0:10 - I show that HairFromGuides is set to 1%
0:13 - Going into the render settings
0:20 - In the “Settings” tab - turn on the “Use Render State in IPR” option. This only works in V-Ray 5 and later versions.
0:30 - Check what we get in V-Ray IPR and see 100% hair. Everything works. Done
