Tuxedo Park Estate
Hello, my name is Steven Garubba and I work primarily as an Architectural Designer for DeGraw & DeHaan Architects.
We just recently finished up the exterior and landscaping of the model in Sketchup so that called for creating a video and many images.
Enjoy!
P.S. The use of proxies was paramount to achieving a realistic environment without slowing down the main model so thank you for that update Enscape.
Wow, great images and video! Thanks for sharing! You put the depth of field to good use :wink:
Thank you Thomas! It’s definitely a great simple tool to get cinematic shots.
NICE JOB! Really like the camera angles you chose and the music was very appropriate to the design as well.
Would you mind me asking how long it too to export all the video sequences from Enscape and on what hardware?
Thanks Bendbox!
Sure! Capture settings were set to typically 7-10 seconds, 30 fps and it took roughly 40 mins render each scene. Once rendered, I reduced a couple of the scene’s speeds to match other speeds in a video editing program.
At work, I’m running on a Dell Precision 3620
Processor: Intel Xeon CPU E3-1270 v5 @3.60GHz
RAM: 32 GB
GPU: Nvidia Quadro M4000
Thanks for the info SGarubba!
