Understanding DMC Sampler
I was hoping someone can have a look over these two elements, both are from the same scene but using different DMC sampler settings, and perhaps give me an insight as to what is going on.
This first one is 1/50, clr thresh 0.007
This second one is 1/16 clr thresh 0.003
I follow with interest various threads that touch on using this element to understand noise, (a lot of input from joconnell actually so hope he sees this!) and I’ve concluded that the second image is what should be expected if the dmc sampler is working most effciently, a nicely balanced ‘heat map’.
However, that image rendered in 4.5 hours, the first in 38 mins, with no real difference in the beauty passes! Now of course I can simply stick with the settings for the first image as I’m happy with the result, but I’m not understanding why these settings work, can anybody help?
And I’ve read the demystifying dmc sampler article a number of times but am struggling to understand that too!!
Cheers, Michael.
At the end of each render, V-Ray will print some statistics about the number of camera/reflection/refraction/shadow/GI rays, as well as the total number of traced rays. Compare the numbers between the two renders - it should help to figure out where the difference comes from. I suppose that it might be good to put these into their own render elements too.
Hi Vlado,
Where are those statistics, the job was rendered through backburner?
Cheers, Michael.
AFAIK
1. red in the second image means that 16 as max DMC is not enough for the required clr thresh (0,003)
2. red for large areas for me it’s no good; it should be confined to very small portion of the image
Vlado:
I’m all for more statistics and predictability in the dmc sampler as you can guess by my stupid questions over the past while :smile: - The sample rate element is a really handy diagnostic tool to start with and a similar tool for reflection, refraction and lighting would be amazing too - I think you mentioned that it’d have a memory overhead and I’d imagine also a cpu overhead for the extra sums but during the tweaking stage I think I’d find it really useful
Michael - beware, long post that has to be split in two for forum letter counts :smile:
With your sample rate element, it only deals with your anti aliasing sampling and nothing else. In your first image of 1/50, you’re getting no red values so it means that no part of your image requires your upper 50 value of aa sampling, nothing anywhere near that in fact so it means your aa is more than the scene needs. It looks like it’s a geometrically and bump texture simple scene so it doesn’t need massive aa. With the second image, your aa has gone down a lot so now you’re getting way more red pixels as far more parts of the image are using your lowered ceiling of 16 aa samples. The lowered colour threshold is making vray use a fair finer level of quality before it can finish rendering too - I’d be interested to see your render times at 1/16 if you’d left the colour threshold at 1/16 and 0.007.
If I was to take a guess, I’d say your scene is being heavily lit from outside, so all of the complicated sampling in your image will be down to a really wide range of brightness, your glossy reflections on the floor covering such a large area, and then the very soft shadows coming in from your window light. If you have a look at the red pixels, they’re on the smooth curving lines of the chairs, and on the edges of the window frame. I’d say the wall lines at the window and around the skirting board aren’t getting hit with very bright light, so they get medium green sampling - geometrically they’re the exact same as the lines making up the window panes, the only difference is the pixels along the edges of the window panes are being blasted with whatever bright or complex light source is outside the window, so vray is putting additional AA samples there to deal with the difference in brightness values between the inside normal exposure and then the extremely bright rim pixels. So you probably don’t need to use much aa sampling, but you need to up your light samples for your main window light source, and likely the reflection samples on the floor material. Could you pop up a Raw GI, reflection and raw lighting pass along with the beauty to have another look? I’d say what’s happening with the bottom render is that your reflections are complicated but your floor material reflection samples aren’t that high, thus vray is having to use aa sampling closer to it’s max value to clean it up - hence the red pixels. If you open up your 1/16 scene, see what happens to the sample rate element and render times if you turn up the floor reflection samples by a factor of 4 and render, then set it back to what it was before, then turn up your external light source samples by 4 and render again. I think your scene is more complex in terms of material and light sampling rather than AA so it might make a difference.
In terms of the DMC tutorial there’s a lot in it! I’ve asked a lot of questions to the guys in chaos to try and clear up my understanding of DMC and Vlado and Svetlozar have been brilliant. I’ve to go back to Toni’s tutorial again and re read it knowing what I know now. If you want what I’ve found as relates to it, it’s as follows:
Vray always tries to balance your various samplers to get the cleanest result with the smallest amount of sampling.
Vray’s AA sampler makes the biggest final difference to how it decides sampling.
The sample settings of all of your materials get divided by your top AA setting, so the higher you go with your max AA, the more your material and light settings get divided.
If your material or light sampling is too low, it’ll force your AA to go to higher levels to try and clean up the noisy results that the light or material has returned to it (the cause of your red pixels in the 1/16 render).
Just because you use insane sample values in your materials or lights, it doesn’t mean that vray will actually use those numbers, it just gives it the option of using them.
At the minute with sampling, I find the AA is a good place to start as it provides the most measurable response via the sample rate element - you get a visual reference of exactly what it’s doing, and since the AA sampler is influencing everything else it’s kind of a good “pivot”. Now, the sample rate element WILL change as you tweak other parameters. For example in your 1/16 image above, if you were to either turn up your light samples, or turn up your material reflection samples on the floor, all of the red area on the sample rate element will start to drop off. Since your material is now doing more work, it’ll return a far cleaner result to the aa sampler, and it’ll have to use less of your max aa samples to reach the right level of cleanness for your final image, and this is the vray internal balancing act.
As one method you could try doing this to get things semi predictable:
- Turn on the default scene lights and hide all the others, turn your GI off. Stick on a grey override material so that you get a crap looking render, but the important thing is that you only want to see how vray is sampling your edges.
- Tweak your aa until you get really clean edges and your sample rate is mainly blue and then red at the edges where you need all of the quality.
- Next keep your middle grey material but turn on your proper lighting. With this you’ve got new levels of noise to deal with from the raytracing of your light sources and if you’re using brute force, from the light sampling here too. As a result your sample rate element will change again, as your previously clean, boring surfaces in your grey render now have shadow and highlight areas. The shadows if they’re particularly soft, will need more sampling and cause grain with the default light subdivs, so you’ll find that your sample rate element will now get more red, as your light is causing grain that forces your aa sampler to do more work. What you can do is leave your AA where it is, and turn on your Raw GI and Raw lighting elements. If you’ve got grain in your raw lighting pass, that means you don’t have enough samples in your light source, so gradually turn up the samples until you get something that’s clean enough. Don’t be afraid to use big changes in the value. If you start with 8, try going up to 25, 50 or 100. If I’m using a hdri in a domelight for example, I’ve ended up using values of 400 on the current film I’m working on. So ideally what you can do is maintain the AA settings you’ve had before, and alter your light samples until this is now clean also.
- Last turn on your proper materials. Turning these on means you’re now bringing in noise from glossy materials so again if they’re using low samples, they’ll likely cause some grain which again will cause the aa sampler to again do more work so your sample rate will again go red in the noisy areas. Again this means you’re going to have to up your material samples in the materials so turn on your reflection, raw reflection, specular, refraction and raw refraction elements. The non raw versions are the most important as they’re the level of reflections / refractions which finally end up added into your pixels. The reflection filter element can be useful here too as it’ll tell you exactly how much your reflection is conributing to the final materials - pure white pixels mean 100% reflective, dark grey mean nearly no reflections. If it’s noisy in the raw reflection for a material, but the reflection filter has almost black pixels then it’s quite likely that vray has decided it isn’t important enough to the final result to go up to any higher quality with. In terms of cleaning up reflections I’ve found that glossy reflections themselves are partially to do with their own material sample settings, and second of all the samples of the lighting solution that they’re reflecting. If you take a glossy surface and light it with a hdri, you can clean up noise by either turning up the material samples, or turning up the samples of the light that hits the surface. If you’re unsure which, take a look at your raw lighting channel. If the raw lighting of the surface is pretty clean but your reflections are noisy, up your material samples. If both your lighting and reflection channels are noisy, then up your light.
This is my current method of thinking and understanding vray, if anyone has enough time to read the above nonsense and I’ve got gaps or misunderstanding then I’d love to get any feedback.
-- OVERALL THOUGHTS
With the universal method set up by vlado a while back he didn’t intend the render settings to be the best or the fastest, just a clean and understandable method to get good results for everyone. We’re starting to push Vray a lot harder since version 2.0 and the quality of work has come on hugely, so that method isn’t as relevant in all cases, and where we need to get extremely clean results or fast results then the universal methods won’t be the best option.
Using the sample rate, raw light, raw Gi, raw and non raw reflect and refract and reflection filter passes what you should be able to do is identify what type of scene you have.
If you have really simple geometry but it’s something like an interior room lit by a hdri, then you probably need less AA but more light samples.
If you have a scene where everything is glossy but again it’s simple geometry, you can probably use less AA but more material samples.
If you have a scene where you’ve got lots of complex geometry edges but a simple lighting setup such as a forest or a field with grass, you’ll need lots of AA quality to keep the leaves from sparkling a lot, especially if the camera is moving, and then probably quite a few gi samples to get the right level of detail in all the small light bounces.
If you have an object lit by a bright HDRI that has glossy reflections, you’ll definitely need higher light samples in the dome light with the hdri, and then maybe more reflection samples in materials that have glossy reflections as they’re reflection something with quite a bit of information too.
If you have a scene that’s mainly non reflective - take a room with walls, carpets and furniture but the off shiny object and some small interior lights. This will likely be overall quite clean with low aa, light and material samples save for a few parts. With this you’re best off using your passes or turning lights on and off to find out what materials and what lights are causing the noise and then really heavily upping the samples for these small parts, but keeping the overall scene samples low.
The main thing is to try and identify the cause of the noise and irradicate that, knowing that all the time your AA is reducing the amount of samples everthing else uses, so I like to get the AA roughly right first and then use that as a base to start changing the light and material things.
Hope this helps and doesn’t confuse you even more.
WOW. Amazing input, joconnell, many thanks! I was really hoping you’d get involved as the workflow you’ve just described is kind of how I started this testing process, I’d read it in another thread.
Scene is lit by one domelight, a peter guthrie hdri. Intention was to just use this as only light source as BB3viz did in his ‘old vicarage’ work.
I then went the route of using grey material until I got a really clean rawlighting pass, domelight subdivs at 256, texmap resolution at 2048.
Hopefully you agree that these passes are clean? I don’t normally get this deep into noise, I have stock settings that work great in terms of deadlines and business, but I want to push things further!
So I was happy with cleaness of light and then switched on my already setup materials and got the results. Ok and ready for post, but unacceptable render time of 4.5 hrs using our dr servers with lc secondary and imap primary 3200 x 1800. Normally accept about an hour a render.
So I’m pleased with results and noise levels but not the times, and looked to the samplerate element and got to this point. I’ll do some more tests based on your input tonight, however its worth noting the floor mat has ref subdivs 48, the red leather chair has 64, which I consider very high at the minute…
What do you think to these passes, are they what you expected?
Double post
Righty. The passes look beautiful but let’s try to get them quicker.
Looking at that, I think you’ll need more samples on the floor and maybe the roof to make the aa sampling easier. I reckon you’ll still get some red on the floor but it’ll be more based around the detail in the bump map (which is considered the same as geometric detail, thus it’s an aa thing). I’d be inclined to turn down the res of the hdri to make your light clean up quicker as all of the main surfaces in the scene aren’t reflecting it. If you changed the angle of the camera so the window was in the background and the outside HDRI was then being reflected on the floor, it’d be a different case. Right now though I’d wonder if you’re getting any major benefit from the extra sampling needed. I’d say your AA threshold is probably quite high so I’d experiment with bringing that up to 0.01 and trying to clean with material samples first. If you were still getting noise, you could also look at unlinking the aa sampler colour threshold from the “use dmc threshold” option. Again since the scene is quite simple geometrically, you could perhaps get away with a lower quality on your AA of 0.01, then maybe go lower on your dmc sampler noise threshold of 0.08 or slightly lower.
Vlado - I could be thinking too simply about the relationship between the aa noise threshold and the dmc noise threshold. Is it literally a case of being able to separate the noise levels of the final aa compared to the other fuzzy samplers? Or by unlinking the two is there any other more careful balance broken?
this is very valuable insight, it’s great from your part to take the time and share your method of work and findings on the forums. must admit I’ve learnt a lot from your posts on how the dmc sampler works, especially the idea of render elements as being meaningful in other ways than just compositing. it’s been a real eye opener.
Cheers Rivoli,
The only thing I hope is that I’m not wrong on any of the things I’m writing - it can do as much harm to spread false information as to put up no information at all :smile:
Not sure I follow the last bit of advice joconnell, the passes Ive shown used these settings…
By the way, I totally agree with rivoli, I’ve learned so much from your posts across the forum, it really is invaluable input, very much appreciated.
Ah yes.
So your Adaptive DMC clr threshold can go up to 0.01, and then if it brings in a huge amount of noise in your render, try using the noise threshold in the system tab > Vray Dmc sampler rollout. This will be the noise / quality threshold for the material and light sampling.
Just curious. Would a “heat map” type element be useful to show what buckets took how much time compared to the rest (normalised) to further debug this type of problem? or will the sample rate element cover this?
Hmm - The sample rate is showing you way more detail than the buckets would so you can still use it to chase things down to an object / material level - the more options we have to guide us though the better, once they aren’t taking away development time from other important things. I found when working as a lecturer that people take in information in different fashions, so a way of thinking that works for me mightn’t work for you and vice versa so the more ways we have of looking at a problem the better!
Well I was curious as I must admit I have never really dived too deep into sample rate debugging. Does the red in the sample rate element always equate to longer render times, and inversely, do the blue pixels always render faster?
The sample rate just lets you know what level of anti aliasing the pixels are using. If you’re using adaptive dmc anti aliasing, the blue pixels in your sample rate mean that they’re using the minimum value of your anti aliasing. If you’ve got red pixels it means that they’re using the very maximum level you’ve set in your adaptive dmc sampler. The sample rate element is mainly a guide as to how hard the anti aliaser is working to try and clean up your scene and it’s up to you to decide if you need to either higher or lower your anti aliasing level to get the best balance of quality and speed. The way I’d tend to think is that anti aliasing is mainly there to work on the quality of your edges and your bump detail, so I like to play with the max aa level until I get smooth results in the main beauty render. When I now look at my sample rate element, if there’s a line of red pixels just along the edges of all my objects and the rest is blue, then this is good for me - it means your anti aliasing is only high in the places that you need it. If you’ve got no red pixels at all, it means that the anti aliasing you’ve set has a max value that isn’t being used at all so you can turn it down without harming your image quality.
The red versus blue doesn’t really mean longer or shorter render times, all it shows you is how your anti aliasing is being used through your render. From that though, you can start to work out how all your other samplers are being affected, as the max anti aliasing value will turn down the settings of all other samplers. For example if you’ve got a render of a product sitting on a glossy white plane lit by a hdri, and the sample rate element shows green or red pixels on the flat areas of the plane, it means that whatever result the reflections and lighting is giving to the anti aliaser, it’s not clean enough for the quality you’ve asked for with your noise thresholds, so the anti aliaser is trying to do extra work to clean things up. In the middle of the flat ground plane there’s zero need for high anti-aliasing since you’ve got no edges and you’ve got no bump maps going on. If you’ve got red in your sample rate in these areas then it means that the reflection samples aren’t doing a good enough job (or possibly you hdri light samples) so the anti aliaser is going up to it’s max rate in an effort to clean it up. If you don’t touch your anti aliasing settings at all, but gradually bring up your material reflection settings, the red pixels in the sample rate will gradually start to drop back down towards blue again. It’s all about trying to get each of the samplers to do their job well.
Fred ruff wrote a good post about this back in earlier vray days when the sample rate was only dark blue up to light blue, so if you take the same ideas but use blue to red as your high / low then it’s still valid - http://www.ruffstuffcg.com/journal/de-constructing-vrays-anti-aliasing.html
Yes. Well that is why I thought a render-time heat map for buckets would be ok for this purpose. Hopefully one could then use the heat map as a guide to look at the other elements when looking for noise contributors and / or slowdowns.
I think I’m going to modify my “maxstart.max” file to include all these elements for analysis in a projects early stages. I always forget to add them later on in the project when everything is complicated and messy and render times are already a lot higher. Hopefully this will force me to constantly optimize and clean up as I go along, resulting in less problems total in the end. At least in theory.
Try this as an approach when optimizing:
1. Put on a grey override and hide all scene lights, turn off GI. Turn on default lights in the global switches so you get nothing but a boring grey render in your viewport. Use your sample rate element and max adaptive dmc control until you get clean enough edges on your geometry and get a nice looking sample rate with red only where it’s needed.
2. Turn off default lights, turn on your scene lights and gi. Leave your grey override on and add in the raw lighting and raw global illumination passes. You know that your AA is probably in a good place now so lets not touch that. The sample rate element might go red again due to your lights or GI adding in noise but don’t touch your AA. Try instead adding in more subdivs to your light sources so in the controls of the lights themselves and in the subdivs of brute force GI if you’re using that. Change those settings until your raw light and raw GI are nice and clean (if you use irmap and LC instead of touching brute force then the raw gi is less important) and now when you go back to your sample rate then you should be back to having red only along the edges and blue everywhere else.
3. Turn off your material override and turn on the reflection, raw reflection, refraction and raw refraction elements. Again since these will likely be noisy, your sample rate element will go more red due to the aa sampler trying to clean up noisy materials. Again leave your AA as is, and gradually increase your material reflection / refraction settings until the render elements look clean and your sample rate has returned down to the usual red edge, blue everywhere else type of look.
Hi joconnell,
after some testing based on your input I managed to get the render time of my original 1/16 0.03 render down to 2hrs 17 from 4.5hrs, just by upping my materials to 128 subdivs.
I then lowered clr threshold to 0.05 and now have a render time of 1hr 35 and clean render so I’m very pleased! Also I have a much better understanding of how to use the elements effectively from your workflow, its really helped me out so many thanks.
I’m starting another test on a live project now and have already hit a stumbling block…
When I do this step I simply get a fully black RGB pass and fully blue samplerate element, I must be missing something very simple?!?
