Hello
I’m trying to render animation on Vray GPU and I’m getting these errors on random frames.
It render perfectly fine on Vray Next CPU.
[2019/Jul/9|15:46:57] error: UNHANDLED EXCEPTION: Clearing global light manager.
Last marker is at D:\cgrepo\vray\vray\src\vrayrenderer.cpp, line 4216: Preparing global light manager
[2019/Jul/9|15:46:59] error: [VRayRTMax::Render] generated an exception. Aborting.
[2019/Jul/9|15:46:59] [VRayRTMax::Render()] Cancelled before render
[2019/Jul/9|15:46:59] [RTRenderSession::renderEnd] Calling endSequence()
[2019/Jul/9|15:46:59] error: 5 error(s), 46 warning(s)
[2019/Jul/9|15:46:59] ================================
[2019/Jul/9|15:46:59] Broadcasting NOTIFY_POST_RENDER.
[2019/Jul/9|16:00:45] Saving to file.
[2019/Jul/9|16:00:45] Saving distributed renderer.
[2019/Jul/9|16:00:45] Saving filter parameters.
[2019/Jul/9|16:00:45] Saving done.
[2019/Jul/9|16:25:56] Tiled texture cache set to 4000 MB
[2019/Jul/9|16:25:56] error: Unrecoverable error happened during the last V-Ray GPU session. Restart 3ds Max to continue using V-Ray GPU.
[2019/Jul/9|16:25:56] error: 1 error(s), 0 warning(s)
[2019/Jul/9|16:25:56] ================================
And if I try to render again it ask me to restart 3ds Max
side note : why VRay log in 3ds max show only part of the log and not the full log , I would expect at least for the current render ..in this case I can’t see the 5 error(s), 46 warning(s) that’s mentioned in the message and I have to open the log text in notepad and search through it .
Attached the full log ..let me know of you will need the scene too
vraylog.txt (1.23 MB)
